Giriş
Restore iSight capability by replacing your broken camera board.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
Remove the two 9 mm T8 Torx screws securing the camera board to the rear case.
2 başka kişi bu kılavuzu tamamladı.
