Giriş
Remove your access door to replace RAM chips or to open the case of your iMac.
Neye ihtiyacın var
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
10 farklı kişi bu kılavuzu tamamladı.
