Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95-
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Disconnect the microphone cable connector, removing tape as necessary.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
Remove the two T6 Torx screws securing the display data cable to the logic board.
Use the attached black tab to pull the display data cable connector straight away from the logic board.
Remove the eight T8 Torx screws securing the display panel to the rear case.
Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
With the display panel still lifted, disconnect the four inverter cables.
(combined into one plug in on the 24")
Remove the single T10 Torx screw securing the right speaker to the rear case.
Disconnect the right speaker cable connector from the audio board by pulling it straight up from its socket.
Bir başkası bu kılavuzu tamamladı.
