Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace a broken CPU fan to keep temperatures down.
Neye ihtiyacın var
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws securing the power supply to the outer case:
Two 22.2 mm fine-thread T10 Torx
One 25 mm coarse-thread T10 Torx
One 9 mm coarse-thread T10 Torx
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
Camera cable
Hard drive thermal sensor
Hard drive fan
Microphone
Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
Ambient temperature sensor
Bluetooth cable
If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
Use the flat end of a spudger to pry open the ambient temperature sensor retainer.
Remove the ambient temperature sensor from the CPU fan.
12 farklı kişi bu kılavuzu tamamladı.
