Ana içeriğe geç
iMac Intel 21.5" EMC 2308 RAM Replacement
Neye ihtiyacın var
    1. iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: adım 1, 2 resimden 1. iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: adım 1, 2 resimden 2.
      • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
      • These screws will remain captive in the access door.
      • Remove the access door from your iMac.
      • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
      FixBot'a Sor
      Yorum Ekle
    1. iMac Intel 21.5" EMC 2308 RAM Replacement, RAM: adım 2, 1 resimden 1.
      • Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
      FixBot'a Sor
      Yorum Ekle
    2. iMac Intel 21.5" EMC 2308 RAM Replacement: adım 3, 2 resimden 1. iMac Intel 21.5" EMC 2308 RAM Replacement: adım 3, 2 resimden 2.
      • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
      • Grab the RAM chip by its edges and pull it straight out of its slot.
      • If two RAM chips are installed, repeat this process for the other chip.
      FixBot'a Sor
      Yorum Ekle
Sonuç
112 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
There needs to be a little bit of important discucssion about getting the new RAM properly seated into the slots. Otherwise, great instructions!
Mary - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 81
Her zaman: 91,214
