Giriş
Upgrade your RAM for an instant increase in speed.
Neye ihtiyacın var
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
111 farklı kişi bu kılavuzu tamamladı.
In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
kevmacmills - Yanıt
Definitely! The author should make this as a step in the description (because not everyone reads Comments)
finnik2d - Yanıt
Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
matt - Yanıt
