Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace a broken AirPort card to regain Wi-Fi connectivity.
Neye ihtiyacın var
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry all three AirPort antenna cable connectors up from their sockets on the AirPort card.
10 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Inversion de CH / CH inversion :
J'ai constaté deux fois le même problème en changeant le HDD.
J'ai connecté normalement et ça fonctionne.
I have seen the same problem twice by changing the HDD.
I connected normally and it works.
Avant / Before : 0 = CH 2/1 = CH 1/2 = CHO
Après / After : 0 = CH 0/1 = CH 1/2 = CH 2
