Giriş
Remove the LCD to access most of your iMac's internals.
Aletler
Parçalar
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
27 farklı kişi bu kılavuzu tamamladı.
4 Yorum
My screen does not come on but the dvd player powers up and the orchestral noise in the beginning sounds what do you think the problem is?
