Ana içeriğe geç
  1. iMac Intel 21.5" EMC 2428 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
  2. iMac Intel 21.5" EMC 2428 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
    • Be careful not to contact the AirPort card as you lift the hard drive out of its recess.
  3. iMac Intel 21.5" EMC 2428 Hard Drive Replacement: adım 3, 2 resimden 1. iMac Intel 21.5" EMC 2428 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Disconnect the SATA data cable and SATA power connector from their respective sockets by pulling each connector away from the hard drive.
Sonuç
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 333
