Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to remove your logic board.
Neye ihtiyacın var
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
In the proceeding steps, you will disconnect the following cables:
SD Board
Left/Right Speaker and Microphone
Audio Port
Wi-Fi Antenna
Right Temperature Sensor, Bluetooth/Ambient Light Sensor/Camera/Left Temperature, and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
54 farklı kişi bu kılavuzu tamamladı.
7 Yorum
En Français:
Il n'est marqué nulle part sur ce tuto qu'il ne faut pas toucher les parties métalliques qui tiennent ensemble refroidissement et carte mère. Dès que l'on touche ces parties, l'acier s'oxyde directement et la rouille apparait dans votre iMac alors ATTENTION !
In English:
It's not write in this tutorial that when should not touch with our hands the two metallic parts which hold the motherboard and coolings.
Take care of that because the metal gonna be oxided, and the rust will arrived !
Hey guys....I'm having a problem fitting back the logic board... It refuses to go go back in. It's like it has grown half an inch bigger lol.. Anyway is there any advice anyone can give or tips how to do it..its really annoying me now.
I have the same issue if you found the fix?
i had this issue as well and i figured out that the wall to the right of the power supply was making it difficult to get the logic board back in place; i removed that plastic wall and made sure no cables were blocking the board and it went back in no problem.
Some cables can stay between mother board and box, especially near to optic drive fan.
gerland -
