Giriş
Use this guide to replace your logic board's BR 2032 PRAM battery.
Parçalar
Hiçbir parça belirtilmedi.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
9 farklı kişi bu kılavuzu tamamladı.
