Ana içeriğe geç
iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement, Logic Board Assembly: adım 1, 2 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement, Logic Board Assembly: adım 1, 2 resimden 2.
    • Push on each side of the left speaker cable connector with the tip of a spudger and gently "walk" it out of its socket.
  2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 2, 2 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 2, 2 resimden 2.
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  3. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 3, 3 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 3, 3 resimden 2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 3, 3 resimden 3.
    • In a similar fashion as the previous step, de-route the SATA data and power cables up out of the retaining clip.
  4. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 4, 3 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 4, 3 resimden 2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 4, 3 resimden 3.
    • Use the flat edge of a spudger to flip up the metal retaining bracket on the iSight camera cable connector.
    • Pull the iSight camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  5. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 5, 3 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 5, 3 resimden 2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 5, 3 resimden 3.
    • Use the flat edge of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables.
  6. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 6, 1 resimden 1.
    • If brackets secure the four antenna cables, remove the two T5 Torx screws from the brackets.
  7. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 7, 3 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 7, 3 resimden 2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 7, 3 resimden 3.
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
  8. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the following screws securing the exhaust duct to the rear enclosure:
    • Two 6.3 mm T8 screws
    • Two 4.7 mm T8 screws
  9. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
    • Depending on the age and model of your iMac, a T9 driver may work best.
  10. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 10, 3 resimden 1. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 10, 3 resimden 2. iMac Intel 21.5" EMC 2544 Logic Board Assembly Replacement: adım 10, 3 resimden 3.
    • Tilt the top of the logic board away from the rear enclosure.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear case's screw posts.
    • The I/O boards at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
Sonuç
Sam Goldheart
471.895 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 132
