Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the left speaker.
Neye ihtiyacın var
Bu adımda kullanılan alet:iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Bu adımda kullanılan alet:Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
4 farklı kişi bu kılavuzu tamamladı.
