Giriş
Use this guide to replace the AirPort/Bluetooth card.
Neye ihtiyacın var
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
To reassemble your device, follow these instructions in reverse.
