Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:iMac Intel 21.5" Cardboard Service Wedge$4.99-
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
Continue running the tool up around the top left corner.
Push the tool around the top right corner of the display.
Wheel the tool down along the right side of the display.
Finish pushing the opening tool to the bottom of the right side of the display.
Bu adımda kullanılan alet:Plastic Cards$2.99-
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Gently twist the plastic card sideways to create a gap between the display and frame.
Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
Gently twist the card upward, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
Begin to lift the top of the display up from the frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
Lift the display up from the frame and remove it from the iMac.
It may be necessary to slowly lift from one side to peel against the remaining adhesive.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Remove the lower support bracket from the iMac enclosure.
Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
Remove the two 10 mm T10 Torx screws securing the right speaker to the rear enclosure.
Insert the tip of a spudger between the right speaker and the antenna cable, running it down the right side of the speaker to de-route the cable from its channel.
Tip the right speaker forward out of the rear enclosure, about 1 cm.
Pull the speaker straight up and remove it from the iMac.
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
Two 21 mm screws
One 9 mm screw
One 27 mm screw
Remove the left and right hard drive brackets from the iMac.
Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
Pull the power supply slightly up and out from the rear enclosure.
Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
Slide the power supply to the right to clear the screw posts on the rear enclosure.
Rock the power supply forward and remove it from its recess in the rear enclosure.
Squeeze the tab on the back side of the DC power cable connector and pull it straight out of its socket on the back of the logic board.
Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward.
While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
Gently pull the fan cable connector straight out of its socket on the logic board.
Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
Gently pull the left speaker cable straight out of its socket on the logic board.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
Flip up the metal retaining bracket on the FaceTime camera cable connector.
Pull the FaceTime camera cable straight out of its socket on the logic board.
Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
Two 6.2 mm screws
Two 4.7 mm screws
Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
Tilt the top of the logic board away from the rear enclosure.
You can use a USB flash drive and/or ethernet cable to ensure the logic board is seated correctly while you screw it in.
Remove the T8 Torx screw securing the SSD to the logic board.
Slightly lift the rightmost side of the SSD and firmly slide it straight out of its socket on the logic board.
11 farklı kişi bu kılavuzu tamamladı.
6 Yorum
There’s no PCIe slot on the EMC 2889 motherboard???
It depends!
If you got a SATA drive’d model then that is correct! No PCI/e SSD slot.
But! If you got a Fusion Drive’d model, or one which has a SSD then your logic board DOES have the PCIe SSD slot
Dan -
Hi, for iMac 16.2 no Fusion Drive and no HD/SSD, there aren’t EMC for upgrade/repair? I’ve searched in all place, OWC Aura Pro 2X isn’t compatible with 16.1 and 16.2… I think this model can be only repaired or upgraded (maybe only repaired) in Apple Store. This is right? Best regards
Both the 2015 21.5” iMacs iMac16.1 & iMac16.2 (4k) offer a 8.0 GT/s PCIe x4 custom blade SSD connector on SSD only model as well as with the Fusion Drive model. A straight HDD system will not have the slot hardware!
The problem you are seeing here is the 21.5” A1418 only supported PCIe 2.0 x4 where the 27” A1419 supported PCIe 3.0 x4. The older SSD’s Apple used where PCIe 2.0 x2.
Apple didn’t use the PCIe 2.0 x4 SSD very long which is why you need to stick with the real Apple SSD in this series requires.
