Ana içeriğe geç
iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement, Logic Board Assembly: adım 1, 2 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement, Logic Board Assembly: adım 1, 2 resimden 2.
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 2, 1 resimden 1.
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  3. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 3, 2 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 3, 2 resimden 2.
    • Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
  4. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 4, 2 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 4, 2 resimden 2.
    • Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
  5. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 5, 3 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 5, 3 resimden 2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 5, 3 resimden 3.
    • Flip up the metal retaining bracket on the FaceTime camera cable connector.
    • Pull the FaceTime camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  6. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
  7. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 7, 3 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 7, 3 resimden 2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 7, 3 resimden 3.
    • Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
  8. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 8, 2 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 8, 2 resimden 2.
    • Gently pull the right speaker cable connector parallel to the logic board, straight out of its socket on the logic board.
  9. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 9, 3 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 9, 3 resimden 2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 9, 3 resimden 3.
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
  10. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 10, 1 resimden 1.
    • Peel off the tape covering the exhaust duct.
  11. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
    • Two 6.2 mm screws
    • Two 4.7 mm screws
  12. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 12, 3 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 12, 3 resimden 2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 12, 3 resimden 3.
    • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Gently pull the microphone ribbon cable straight out of its socket.
  13. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 13, 1 resimden 1.
    • Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
  14. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 14, 3 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 14, 3 resimden 2. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 14, 3 resimden 3.
    • Tilt the top of the logic board away from the rear enclosure.
    • When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear enclosure's screw posts.
  15. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 15, 2 resimden 1. iMac Intel 21.5" EMC 3068 Logic Board Assembly Replacement: adım 15, 2 resimden 2.
    • When reassembling your iMac, be sure to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
    • Use a USB flash drive and/or ethernet cable to ensure the logic board is aligned correctly while you screw it in.
Sonuç
Adam O'Camb
210.250 İtibar
416 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 113
