Ana içeriğe geç
iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement
Neye ihtiyacın var
  1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, Display Assembly: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 21.5" Cardboard Service Wedge
    Satın Al
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - Yanıt
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - Yanıt
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - Yanıt
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - Yanıt
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - Yanıt
    There is no replacement glass for this model, it is part of the LCD and impossible to remove or replace- the entire LCD has to be replaced unfortunately if the glass is cracked or damaged. You will have to Google search for a replacement. Also be careful with some of the lock tight tork screws as I broke one of my screw mounts taking one out.
    Phil Tesone - Yanıt
    I used this service wedge but also found it a very tight fit. The same stabilization can be achieved by using a big rolled up towel.
    Ernst - Yanıt
    While this is a good instruction guide, I recommend to also look at OWC’s instruction video about drive installation, before starting the exercise. Those install videos are very detailed and useful.
    Ernst - Yanıt
    Main advice: TAKE YOUR TIME with the pizza roller.
    Make several passes, until you really feel like there's no more sticker in the way. Stay away from the camera though (approx. 1inch / 2.5cm on both sides). This will reduce the work left with the plastic card. Adhesive is really on the edge of the screen so there is absolutely no need to go any further than the recommended 1cm / 3/8inch depth.
    Where are the sensitive parts?
    Facing your iMac, imagine you're looking at a watch. There are antennas on 1, 2 and 4 o'clock. Do not insert any metal piece there (nor anywhere else, btw). Other than that AND the screen cables underneath the camera, not much danger.
    Froggy Manny - Yanıt
  2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 2, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 2, 2 resimden 2.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - Yanıt
    As this guide doesn’t cover replacing the adhesive strips, I found referring to the following was useful (noting that it’s not for the same model of iMac, so the modification they mention wasn’t necessary): iMac Intel 21.5" EMC 2544 Adhesive Strips Replacement
    Alan Digby - Yanıt
    It is very easy to crack the glass in front of the LCD during this step. I used the guitar pick, maybe it was too thick… crack is just on the frame but anyway it is disappointing :(
    Nikolay - Yanıt
    This part of the exercise should be done with extreme patience. I took my sweet time with the opening tool, rolling it through the entire panel and enclosure gap over and over again, until I was very sure no parts were sticking together anymore. And when I thought I was I done, I decided to do it over again.
    Ernst - Yanıt
    You can "warm up" the adhesive before try to cut it with the tool using a hair dryer. Heat the edges for about a minute, keep moving it so you don't cause stress in the glass. Also the above note.. use the tool and then the cards. Do not use a guitar pick or other objects as the thickness will cause you to break the front glass, which is a bonded part of the display (expensive).
    Carl Schultz - Yanıt
    Merci pour ce conseil
    bry nicolas -
  3. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 3, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 3, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 3, 3 resimden 3.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - Yanıt
    If re-opening a screen that was opened and re-attached using iFixit’s adhesive strips, I would strongly recommend heating it first with an iOpener, heat gun or hair dryer. 20 minutes after attaching with the iFixit adhesive I tried to open it again with the pizza slicer to fix something and cracked the screen on the left-hand side.
    plasticpool - Yanıt
  4. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 4, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 4, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 4, 3 resimden 3.
    • Continue running the tool up around the top left corner.
    Ne pincez pas l’écran avec l’autre main. Vous exercez une pression inutile sur le verre et empêchez la roulette de couper le joint.
    phfoglia - Yanıt
  5. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 5, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 5, 2 resimden 2.
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 6, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 6, 2 resimden 2.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - Yanıt
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - Yanıt
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - Yanıt
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - Yanıt
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - Yanıt
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
    The key thing is to never put any force on the opening tool when working through the tape. Just roll it back and forth with ease.
    Ernst - Yanıt
  7. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 7, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 7, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 7, 3 resimden 3.
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 8, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 8, 2 resimden 2.
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 9, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 9, 2 resimden 2.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - Yanıt
    Would be good data to show the 3 areas (wifi antennas where the "tape" is larger and covers them. The rest of the "tape" is 1.4" and easy. Also after removing the display, be sure to remove the old "tape" from both the display and the rubber parts of the case. Use the spudger to start an end and it should pull off easily. Careful on the baackside of the display as you can scratch off the black paint/covering.
  10. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 10, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 10, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 10, 3 resimden 3.
    Plastic Cards
    $2.99
    Satın Al
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - Yanıt
    I drew a 3/8” line on my cards with a marker first.
    Max Romano - Yanıt
    I’m reading this on the EU store, please change all measurements to cm/mm.
    Morgana Devina - Yanıt
    @ifixit The next batch of cards you create should have a line printed on the card 3/8” in from the edges. Would make a nice reference.
    Richard Giratd - Yanıt
    Here’s where OWC provides glass removal suction cups, which is a better solution than plastic cards.
    The suction cups help to easily lift the glass panel, without risking the damaging of any internal wiring that the plastic cards could cause.
    Ernst - Yanıt
    Better to remove stand wedge at this point? Can’t see from pics
    derekrobinson - Yanıt
  11. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 11, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 11, 2 resimden 2.
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - Yanıt
  12. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 12, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 12, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 12, 3 resimden 3.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - Yanıt
    Using glass removal suction cups will avoid running this risk of damaging the camera (or any wiring).
    Ernst - Yanıt
  13. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 13, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 13, 2 resimden 2.
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 14, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 14, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 14, 3 resimden 3.
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 15, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 15, 2 resimden 2.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 16, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 16, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 16, 3 resimden 3.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 17, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 17, 2 resimden 2.
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 18, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 18, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 18, 3 resimden 3.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, Display Assembly Cables: adım 19, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, Display Assembly Cables: adım 19, 2 resimden 2.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
    It was difficult to remove this connection. I ended up having to gently pull-up vertically a little on the wire side to unsnap it about 1mm and then horizontally wiggle it out.
    delacrj2 - Yanıt
    I had a difficult time removing this connection. I had to lift the wire-side about 1mm before it unsnapped and then carefully wiggle it out horizontally.
    delacrj2 - Yanıt
    Can this cable be replaced? I am worried mine is damaged. I have no display after the screen fell and stressed the display flex cables following an SSD upgrade.
    Jeremy Brainard - Yanıt
    This step should be done with extreme caution and care, as this step 19 is not described in great detail (sorry, author).
    The first (most outward) cable will slide out by gently pulling it by its tabs. The second (inner) cable is more tricky, as the locking lever must be moved backward first, before gently pulling backward on the cable connector. The angled tweezers are useful here, to help lift that locking lever, because fingers are too big for this.
    Ernst - Yanıt
    be VERY careful and SLOW...take your time. These displays crack VERY easily when removing and they'll spider web on you. I've done probably 20 or so of these and cracked 3 being super careful.....ugh.
    Faslane - Yanıt
    I found the best way to unplug this display power cable was to use my right hand, and the fingernails of my index finger and thumb to grab the ends of the tabs on either side of the connector, squeeze, and pull the connector out gently.
    Phil McInnis - Yanıt
    i think the cable nearest the case edge is held in by friction and can be gently pulled, maybe with fingernails or a spudger. The next cable is held by a wire lever clip as described above it unlocks so the cable can be removed. These cables are also fiddly to re-insert, I didn't get one of them home and had no display after power-up, so at the end, don't re-seal the screen until tested.
    Peter Taffs - Yanıt
  20. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 20, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 20, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 20, 3 resimden 3.
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
    Cannot seem to find a replacement cable for this, as I suspect mine is damaged. Can’t even find a part number. Anyone know what it might be?
    https://www.amazon.com/gp/product/B08TTL...
    That's the part I ordered for mine and it seems to work ok. I did make a point of contacting the seller and advising them of my requirement and they ensured I got the right part and it matches the description of the link. Bear in mind I bear no responsibility if yours does not work since I am just sharing what I did and what I ordered. Thanks.
    Jim Stanford -
    I also need that cable.
    cameronjpu - Yanıt
    It's a little difficult to tell... but looking at the connection to the logic board on the video data cable, are the pins faced up or down?
    On the display, same question since it appears you have to "twist" the cable during the reconnection step.
    Jim Stanford - Yanıt
    For this particular cable, take a good look before pulling on anything. Plug is locked on its socket with a bracket. You can lift this bracket by holding the small, flat black plastic handle that is attached to it. If you're struggling to grab it, use the end of the pizza roller handle to lift it, or the tweezers. Cable then comes off by pulling parallel to the main board.
    How can I tell if either of this cable is bad? My iMac display won't turn on after reconnecting it. I'm using an external display and everything is working except for the iMac display. If I go to settings - display the built-in display is recognize. But again nothing shows up in the screen - not even the apple logo when turning it on.
    Carlos Sosa - Yanıt
  21. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, Display Assembly Separation: adım 21, 2 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, Display Assembly Separation: adım 21, 2 resimden 2.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    The best way to remove the chin adhesive is to use the tabs at either end (there are two strips that run from each outside corner to near the centre). Carefully pull the tabs up and the strips should peel off.
    Advance Technical Service - Yanıt
  22. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 22, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 22, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 22, 3 resimden 3.
    Plastic Cards
    $2.99
    Satın Al
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
    At step 21-22, releasing the adhesive strips from the bottom of the display, I noticed a tab on the outer end of each strip. Pull the tab to remove the whole strip, no need to mess around with the plastic cards!
    Instead of the plastic cards, use the flat end of a spudger. Use it as scraper. Be careful as there are antennas mounted on the inside edge of the frame on the right side (facing you), and the top right (facing you). The original adhesive strips are on those as well. - ECJ
    ECJohansen - Yanıt
    A little bit of hot air (eg. hair dryer) will help soften the adhesive. Use a piece of cardboard or equivalent if you want to avoid blowing hot air towards the electronics.
    Be careful to remove absolutely everything - any remainder will create a bump and prevent your screen from sticking back to the frame when reassembling.
  23. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 23, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 23, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 23, 3 resimden 3.
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
    Après l'étape 23, j'ai suivi les instructions de la vidéo intitulée: Upgrade RAM in a mid-2017 21-inch iMac without complete disassembly.
    Lien: https://www.youtube.com/watch?v=_k9I7N9B...
    J'ai pu upgrader la RAM en enlevant juste le ventilateur.
    Koala - Yanıt
  24. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: adım 24, 1 resimden 1.
    • Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
    • There's a small washer on each screw; be careful not to misplace them.
  25. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 25, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 25, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 25, 3 resimden 3.
    • Use a spudger to disconnect all four antenna connectors by prying them up from their sockets on the AirPort/Bluetooth Card.
  26. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 26, 1 resimden 1.
    • Remove the two 3.3 mm T5 Torx screws securing the AirPort/Bluetooth card to the logic board.
  27. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 27, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 27, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 27, 3 resimden 3.
    • Gently push the antenna cables aside to clear access to the AirPort/Bluetooth card.
  28. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 28, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 28, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 28, 3 resimden 3.
    • Do not push the AirPort/Bluetooth card away from the logic board more than 1-2 mm. Doing so may cause severe damage.
    • With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board.
    • Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
  29. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 29, 3 resimden 1. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 29, 3 resimden 2. iMac Intel 21.5" Retina 4K Display (2017) AirPort/Bluetooth Card Replacement: adım 29, 3 resimden 3.
    • During reassembly, if installing the AirPort card proves challenging, you can use curved tweezers to help orient the card and insert it into its slot on the back of the logic board.
    • With the tweezers pointed downwards, insert the points of the tweezers through the screw holes in the AirPort card, next to its antenna connector sockets.
    • Using your finger, press down on the edge of the AirPort card to angle it until it is roughly parallel to the logic board.
    • Align the AirPort card with its slot on the logic board, and press the card into the slot until the screw holes nearest the connector align with those in the logic board.
    • For reference, the third photo shows the logic board removed and flipped over for a clear view of how the AirPort card is installed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
196.251 İtibar
416 adet Kılavuz yazıldı
3 Yorum
Hello, I would like to know which other airport is compatible with this model of IMAC 21.5 "? I have 1 2017 4k but do not find to buy this Airport and maybe it is compatible with another, can you help me?
Jonathas - Yanıt
Thanks for the guide Asam!
@johnninfor
Yes, I would like to know as well the exact model number for iMac 21.5 4K 2017? The other iMac guides sugged another module that may not be compatible with this model? The only bits that are readable are BCM?
Oh, I saw it - step 29, I must be blind ;) It’s BCM943602CDP, thanks!
Martin Lambev - Yanıt
I may have damaged the sockets for the antenna connectors (#1 and #3 reading from L -R) in the process of reassembling my late 2017 iMac after replacing my 8 GB RAM DIMMs (REMBER testing after a kernel panic failed, and OWC sent me new DIMMs, which pass REMBER testing.
However, now I cannot pair my BT mouse, or unlock the iMac with my Apple Watch, or pair my AirPods Pro reliably. Curiously, my Magic keyboard works just fine. When the AirPods Pro seem to pair, the music playback to them is awful (stuttering). I know that I couldn’t pop those two antenna connectors onto the little pins on the BT/Airport board the way they were before, but I don’t seem to have any network issues (SPEEDTEST results are similar to previous testing). I don’t know where to get an Airport/BT card or whether that really is my issue, but it certainly corresponds to making the repair. I did reset NVRAM and delete the BT p-list files; neither of those seemed to make any difference.
Jim Robertson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 32
Son 30 gün: 111
Her zaman: 5,968
