Ana içeriğe geç
iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Install the iMac service wedge: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 21.5" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Insert the opening tool: adım 2, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Insert the opening tool: adım 2, 2 resimden 2.
    • Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  3. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Slice through the display adhesive: adım 3, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Slice through the display adhesive: adım 3, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement, Slice through the display adhesive: adım 3, 3 resimden 3.
    • Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
    • Be sure to always push with the cutting wheel forward. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 4, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 4, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 5, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 5, 2 resimden 2.
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 6, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 6, 2 resimden 2.
    • Continue along the top of the display.
    • You may want to run the tool back and forth a few times to ensure you completely cut through the adhesive.
  7. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 7, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 7, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 7, 3 resimden 3.
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 8, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Push the tool down along the right side of the display.
  9. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 9, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 9, 2 resimden 2.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 10, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 10, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 10, 3 resimden 3.
    Plastic Cards
    $2.99
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 11, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 11, 2 resimden 2.
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 12, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 12, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 12, 3 resimden 3.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 13, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 13, 2 resimden 2.
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 14, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 14, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 14, 3 resimden 3.
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 15, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 15, 2 resimden 2.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 16, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 16, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 16, 3 resimden 3.
    • Slide the plastic card toward the center.
    • Stop sliding just before the iSight camera to avoid damaging the camera.
  17. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 17, 2 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 17, 2 resimden 2.
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 18, 3 resimden 1. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 18, 3 resimden 2. iMac Intel 21.5" Retina 4K Display 2019 Display Assembly Replacement: adım 18, 3 resimden 3.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
Sonuç
Adam O'Camb
210.250 İtibar
416 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 171
