Giriş
If the fan in your 21.5" Retina 4K Late 2015 iMac (EMC 2833) is faulty, failing, or badly clogged with dust, use this guide to replace it and return your iMac to cool and quiet operation.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Gently pull the fan cable connector straight away from its socket on the logic board.
Neredeyse bitti!
Sonuç
