Ana içeriğe geç
iMac Intel 24" EMC 2111 Logic Board Replacement
Neye ihtiyacın var
  1. iMac Intel 24" EMC 2111 Logic Board Replacement, Access Door: adım 1, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement, Access Door: adım 1, 2 resimden 2.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 Logic Board Replacement, Front Bezel: adım 2, 1 resimden 1.
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
    My iMac had four 6mm T8 Torx screws (so not one 8mm screw)
    floor - Yanıt
    My late 2006 iMac24 also has only 4, 6mm long T8 screws here.
    JC Gidley - Yanıt
  3. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 3, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 3, 2 resimden 2.
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
    My iMac did not have the "small bridge of material" mentioned, however the bezel just lifted off easily.
    maccentric - Yanıt
  4. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 4, 3 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 4, 3 resimden 2. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 4, 3 resimden 3.
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 5, 1 resimden 1.
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 6, 3 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 6, 3 resimden 2. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 6, 3 resimden 3.
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
    I found it easier not to remove the cables connecting camera and microphone, but rather to lean the plastic frame agains a pile of books so that it could rest almost vertical avoiding the need to disconnect those two sensitive cables.
    Stefano C - Yanıt
    I agree that for a simple, quick battery change, don't risk damaging those delicate wires. Ignore Step 6 and instead of disconnecting the mic and camera wires, keep them in place and just have a friend hold the plastic frame up while you change the battery, or prop it up as mentioned by Stefano C above.
    WT Kwok - Yanıt
    Make sure you double check the new logic board for the presence of the GPU assembly before installing. I stupidly installed a new board without moving the GPU from the old one first. So i guess you can say this guide worked for me twice. :)
    Trevor Kearsey - Yanıt
  7. iMac Intel 24" EMC 2111 Logic Board Replacement, Display Assembly: adım 7, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement, Display Assembly: adım 7, 2 resimden 2.
    • Peel the two highlighted EMI shield tabs off the frame of the LCD.
  8. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 8, 1 resimden 1.
    • Remove the two T6 Torx screws securing the display data cable to the logic board.
    Wait, we need a T6 screwdriver as well?
    I purchased the T8 and T10 from your site as per the parts list above and now am here with an opened iMac on the dining room table unable to continue :/
    Stephen Alianiello - Yanıt
  9. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 9, 1 resimden 1.
    • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
  10. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 10, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 10, 2 resimden 2.
    • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
    • De-route the inverter cable from its location next to the CPU fan.
  11. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 11, 1 resimden 1.
    • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
    • Remove the eight T8 Torx screws securing the display assembly to the rear case.
    • It is helpful to use a thin magnetized screwdriver to remove these screws.
    It would be useful to use a torx screw driver with a long, narrow shank… some of these screws are in tight places.
    Joe Liscouski - Yanıt
    It may also be useful to prop up the back so it is level. This will prevent the screws from falling inside. They can be retrieved once the scene is off.
    John-Francis mergen - Yanıt
  12. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 12, 1 resimden 1.
    • Remove the display assembly from the iMac.
  13. iMac Intel 24" EMC 2111 Logic Board Replacement, Right Speaker: adım 13, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement, Right Speaker: adım 13, 2 resimden 2.
    • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
    • Peel the tape away from the lower corner of the right speaker.
  14. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 14, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 14, 2 resimden 2.
    • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
    • Disconnect the cable from the logic board.
  15. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 15, 1 resimden 1.
    • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
  16. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 16, 1 resimden 1.
    • Pull the right speaker away from the logic board and remove it from the iMac.
  17. iMac Intel 24" EMC 2111 Logic Board Replacement, Logic Board: adım 17, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement, Logic Board: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
    • The black antenna attaches closest to the bottom edge of the iMac.
  18. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 18, 1 resimden 1.
    • Use both fingertips to disconnect the camera and microphone cable from its socket on the logic board.
    • Pull the connector perpendicular to the face of the logic board.
  19. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 19, 1 resimden 1.
    • Pull the optical drive fan connector toward the top edge of the iMac to disconnect it from the logic board.
  20. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 20, 1 resimden 1.
    • Pull the left speaker connector toward the top edge of the iMac to disconnect it from the logic board.
  21. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 21, 1 resimden 1.
    • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from its socket.
  22. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 22, 1 resimden 1.
    • If necessary, remove the strip of tape covering the optical drive connector.
  23. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 23, 3 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 23, 3 resimden 2. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 23, 3 resimden 3.
    • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
    • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
    • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
  24. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 24, 1 resimden 1.
    • Disconnect the hard drive thermal sensor and hard drive fan cables from the logic board by pulling their connectors toward the top edge of the iMac.
  25. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 25, 1 resimden 1.
    • Pull the CPU fan connector toward the left edge of the iMac to disconnect it from the logic board.
  26. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 26, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 26, 2 resimden 2.
    • Disconnect the power button cable from the logic board.
    • Pull its connector perpendicular to the face of the logic board.
  27. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 27, 1 resimden 1.
    • Use the flat end of a spudger to pry the single Bluetooth antenna off its socket on the Bluetooth board.
  28. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 28, 1 resimden 1.
    • Pull the ambient temperature sensor cable perpendicular to the face of the logic board to disconnect it from its socket.
  29. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 29, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 29, 2 resimden 2.
    • Disconnect the DC-In cable from the logic board by pulling its cable toward the right side of the iMac while depressing its locking mechanism.
    • It is helpful to use a spudger and pry from alternating sides of the connector to help "walk" it out of its socket.
  30. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 30, 3 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 30, 3 resimden 2. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 30, 3 resimden 3.
    • Pull the hard drive SATA data cable perpendicular to the face of the logic board to disconnect it from its socket.
    • To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket.
  31. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 31, 1 resimden 1.
    • Peel the foam tape off the top edge of the heat sink framework.
  32. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 32, 1 resimden 1.
    • Remove the following ten screws:
    • Three 6.6 mm T10 Torx fine thread screws
    • Three 7 mm T10 Torx coarse thread screws
    • Two 9.3 mm T10 Torx coarse thread screws
    • Two 5.3 mm T10 Torx coarse thread screws
  33. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 33, 2 resimden 1. iMac Intel 24" EMC 2111 Logic Board Replacement: adım 33, 2 resimden 2.
    • Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel.
    • Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
    • When reinstalling the logic board, it is helpful to use tape to temporarily tuck the cables out of the way until the board is properly seated in the rear case.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
HI hello, I´m having some problems with this iMac; can someone help me, please. I change the hard drive for a SSD, The problem is there isn´t a startup sound and also no video signal shows, when I turn on, everything is perfect, the 3 fans start running, but thats all.
I´m trying to find the possible damage part with no success.
Could be the motherboard?
Where I can buy it?
Thank you very much and excellents manuals, I always look here.
Victor G M - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 25,184
