Ana içeriğe geç
Giriş
Internal prerequisite.
  1. iMac Intel 24" EMC 2111 Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Remove the strip of tape covering the optical drive cable connector.
  2. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 2, 2 resimden 1. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
    • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
  3. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
  4. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from the logic board.
  5. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Peel off the strip of EMI tape attaching the right side of the optical drive to the rear case.
  6. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 6, 1 resimden 1.
    • Push down on the optical drive bracket retaining clip while pulling the top edge of the optical drive away from the rear case.
  7. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 7, 2 resimden 1. iMac Intel 24" EMC 2111 Optical Drive Replacement: adım 7, 2 resimden 2.
    • Rotate the optical drive slightly toward the bottom edge of the iMac while pulling it away from the rear case to release the lower retaining clip.
    • Pull the optical drive away from the right side of the rear case and remove it from the iMac.
Sonuç
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 236
