Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Disconnect the hard drive thermal sensor by pulling its connector upwards toward the top of your iMac.
Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
Rotate the hard drive toward yourself, then lift it up off its mounting pins.
Insert the flat end of a spudger between the SATA power cable connector and the edge of the hard drive.
Twist the spudger to separate the connector from the hard drive.
Pull the SATA power connector away from the hard drive.
Disconnect the SATA data cable by pulling its connector away from the hard drive.
