Giriş
Use this guide to replace a broken display panel on your iMac.
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Remove the two 5.3 mm T6 torx screws from the LCD connector.
Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
20 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
how did you guys go about replacing the black tape that covers the cable on the back of the lcd ?
