Ana içeriğe geç
iMac Intel 27" EMC 2390 Access Door Replacement
Neye ihtiyacın var
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: adım 1, 2 resimden 1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: adım 1, 2 resimden 2.
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 9,367
