Ana içeriğe geç
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as highlighted in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk will do nicely.
  1. Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel. Pull the glass panel away from the lower edge of the iMac and carefully set it aside. Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
121.812 İtibar
143 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
137 Üyeler
16.765 adet Kılavuz yazıldı
3 Yorum
Goods councils.
Frederic Morelli - Yanıt
The glass of my iMac is broken and I want to fix it now. I consider to use a frame instead of a new glass in order to reduce reflections. I saw such a frame on macframe dot com and berlin1000 dot com. I wonder if anybody knows the exact measurements of the glass or has a technical drawing of it. If so, I would be able to laser cut it on my own.
2091212 - Yanıt
Do everything in your power to avoid touching the inside of the glass with your fingers, or the LCD. Please give me his fingerprints is like washing and oiled animal with water
Kevin McCartney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 50
Her zaman: 13,513
