Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will help you replace the optical drive fan.
Neye ihtiyacın var
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Remove the four T10 Torx screws securing the optical drive to the outer case.
Carefully move the rear I/O board ribbon cable to reveal the optical drive fan connector hidden underneath.
Disconnect the optical drive fan by pulling its connector away from the socket on the logic board.
Remove the single T10 Torx screw securing the optical drive fan to the outer case.
Pull the optical drive fan away from the outer case to lift it off the three plastic posts around its perimeter.
Carefully maneuver the optical drive fan out of the iMac, minding any cables that may get caught.
11 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Go slow, and take your time. Easy as long as you do not rush it.
Wish a view of the back of the fan was included to determine what fan specs are needed for replacement. ifixit doesn’t have the part.
