Giriş
Use this guide to replace a faulty SD Board.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
4 başka kişi bu kılavuzu tamamladı.
Bir Yorum
One must consider, the USP based card adapter is like five dollars.
When I tell customers this, they usually get that instead of paying me $100 plus parts to repair it
