Ana içeriğe geç
iMac Intel 27" EMC 2429 Graphics Card, CPU, Hard Drive, Ram Upgrade
Neye ihtiyacın var
    • First Start by unplugging all cables from your iMac and setting up a workstation.
    • You will need a large workstation to hold the iMac and it's parts.
  1. Bu adımda kullanılan alet:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Satın Al
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Electronic Cartel
85 İtibar
1 Kılavuz yazıldı
3 Yorum
Where is the rest of this guide?
Andrew Gannon - Yanıt
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
Bernhard - Yanıt
Non è una guida. Manca tutto!
Giacomo Santerini - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 94
Son 30 gün: 411
Her zaman: 1,689
