Giriş
This guide will help you replace the LED driver board.
Parçalar
Hiçbir parça belirtilmedi.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Carefully lay the iMac stand-side down on a flat surface.
Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
Raise and hold the display high enough to access the cables.
Lay the display face down on a flat, soft surface.
If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Remove the four T10 Torx screws securing the LED driver board to the outer case.
16 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Hello - I have this same issue and tried to complete this repair, but the VSync connector on the new LED Driver Board is different. Has anyone had this issue? Know of a reason why? Any help would be appreciated.
Thanks
I have found two different inverter boards in the 27” 2011 iMacs. One, like shown here, has a 4 pin connector on the top edge that a small connector with 2 wires coming directly from the LCD panel plugs into. The other has an 8 pin connector with a cable about 16” long that goes from that connector to the 8 pin connector on the logic board labeled BLC_ACDC. I’ve come across this configuration 2 or 3 times, out of 40+ iMacs I’ve refurbished.
The inverter board with 8 pins has a part number of V267-E02HF and they sometimes show up on eBay. The cable has a part number of 593-1435 and they’re impossible to find.
tpluth -
With the V267-E02 inverter installed, I have seen panel LM270WQ1 (SD)(E5) used instead of the normal LM270WQ1 (SD)(E3).
tpluth -
Is there a chance the cable is bad? I just replaced my logic board and now the PC is up and running normal but the screen is dark, I see the desktop if I shine a light on the screen.
How can we test if possibly the cable is broken?
