Ana içeriğe geç
iON SnapCam 1045 Wearable HD Video Camera Battery
Neye ihtiyacın var
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: adım 1, 1 resimden 1.
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: adım 2, 1 resimden 1.
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: adım 3, 1 resimden 1.
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: adım 4, 2 resimden 1. iON SnapCam 1045 Wearable HD Video Camera Battery: adım 4, 2 resimden 2.
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Olakunle
102 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Fall 2017 IUPUI, Team S3-G3, Wilson Fall 2017 üyesi
IUPUI-WILSON-F17S3G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 691
