Ana içeriğe geç
iON SnapCam 1046 Lite Battery Replacement
Neye ihtiyacın var
  1. iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: adım 1, 2 resimden 1. iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: adım 1, 2 resimden 2.
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Battery Replacement: adım 2, 1 resimden 1.
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Battery Replacement: adım 4, 3 resimden 1. iON SnapCam 1046 Lite Battery Replacement: adım 4, 3 resimden 2. iON SnapCam 1046 Lite Battery Replacement: adım 4, 3 resimden 3.
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Battery Replacement, Battery: adım 5, 2 resimden 1. iON SnapCam 1046 Lite Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Use a nylon spudger to gently pry the four tabs holding the motherboard in place.
  6. iON SnapCam 1046 Lite Battery Replacement: adım 6, 2 resimden 1. iON SnapCam 1046 Lite Battery Replacement: adım 6, 2 resimden 2.
    • Lift the motherboard to reveal the battery compartment. Remove the thermal tape holding it in place and replace battery.
    • WARNING: Lithium Battery!
Sonuç
Travis Leondis
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S22-G4, Bayer Fall 2017 IUPUI, Team S22-G4, Bayer Fall 2017 üyesi
IUPUI-BAYER-F17S22G4
5 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
Can you please list the battery specifications for selecting the correct replacement battery?
Thank you for the posting and assistance.
james - Yanıt
Where can I find a replacement battery?
Issis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 511
