Ana içeriğe geç
iOpener (Legacy) Instructions
Neye ihtiyacın var
  1. iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: adım 1, 3 resimden 1. iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: adım 1, 3 resimden 2. iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: adım 1, 3 resimden 3.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iOpener (Legacy) Instructions: adım 2, 1 resimden 1.
    • Heat the iOpener for one minute.
    • If you are using a new, liquid-filled iOpener, only microwave your iOpener for 30 seconds, and be sure to follow the appropriate guide.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional minute at a time.
    • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
  3. iOpener (Legacy) Instructions: adım 3, 1 resimden 1.
    • Remove the iOpener from the microwave, holding it by the printed tag.
    • If your iOpener has no tag, grab it by a corner, or handle with an oven mitt to avoid burning yourself.
    • The bag will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iOpener (Legacy) Instructions: adım 4, 1 resimden 1.
    • Lay the iOpener flat on the edge of the device, over an adhesive seal you wish to heat. Smooth the iOpener along the surface to ensure good contact with the device.
    • Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
    • At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
    • Throughout the procedure you may need to reheat the iOpener. To prevent overheating the iOpener, always wait at least two minutes before microwaving again. Do not microwave the iOpener for more than one minute at a time.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
512.431 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.788 adet Kılavuz yazıldı
2Kılavuz Yorumları
It's now a couple of years since I got my iOpener but I never got to use it. I've had to destroy it.
It is essentially a wheat bag (although the seeds in it are not wheat) that has brought some sort of insect into my home, probably from China where it was made.
I was going to report it to Australian Quarantine when I found it has been replaced by the mark 2 that does not involve importing undeclared biological matter.
Jeff Armstrong - Yanıt
this opener is dangerous. After taking it our of the micro wave the outer skin was burst. I got first degree burns. This item should not be used without protection! Chinese $@$*!
Dimitrios Mitrentsis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 63
Son 30 gün: 275
Her zaman: 26,424
