Ana içeriğe geç
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. iPad 10 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPad 10 Chip ID, Main Board Side 1: adım 1, 2 resimden 1. iPad 10 Chip ID, Main Board Side 1: adım 1, 2 resimden 2.
    • Chip ID part 1:
    • Apple APL1W01/339S00803 A14 hexa-core applications processor layered under SK hynix H9HKNNNCRMMVFR-NEH likely 4 GB LPDDR4X SDRAM memory
    • Kioxia K5A2JW30I8TAI2217 ? 64 GB NAND flash
    • Apple APL1094/343S00564 power management
    • Apple APL1099/343S00565 power management
    • Texas Instruments SN2610A0 battery charger
    • Broadcom BCM15957A0 touchscreen controller
    • Texas Instruments CD3217B13 USB type-C controller
  2. iPad 10 Chip ID: adım 2, 1 resimden 1.
    • Chip ID part 2:
    • Analog Devices MAX98709B audio amplifier
    • Winbond W25Q80DV 1 MB serial NOR flash memory
    • Apple/Cirrus Logic 343S00377 power management
    • Likely Texas Instruments USB 2.0 dual repeater
    • Texas Instruments LM3638 backlight LED driver
    • Texas Instruments TPS61230A 6 A / 5 V step-up converter
    • Texas Instruments SN1705004A0 DC-DC converter (likely)
  3. iPad 10 Chip ID: adım 3, 1 resimden 1.
    • Chip ID part 3:
    • Texas Instruments TPD4S311A USB type-C port protector
    • Texas Instruments TVS2200 surge protection
    • Nexperia 74AVC1T45 dual-supply voltage level translator/transceiver
    • Nexperia LSF0101 1-bit multi-voltage level translator
  4. iPad 10 Chip ID: adım 4, 1 resimden 1.
    • Chip ID part 4 - connectivity:
    • NXP Semiconductor SN210 NFC controller w/ secure element
    • USI 339S01015 WiFi/Bluetooth module
  5. iPad 10 Chip ID: adım 5, 1 resimden 1.
    • Chip ID part 5 - sensors:
    • Bosch Sensortec BMI282 6-axis accelerometer/gyroscope
    • Bosch Sensortec pressure sensor
    • Alps hall sensor
2Kılavuz Yorumları
this iPad get water damage and it would just turn on apple logo and turn itself off,
Neclus ADams - Yanıt
keep in mind l did a factory restore or tried to install the operating system and it didn't work
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 210
Son 30 gün: 1,142
Her zaman: 19,749
