Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iPad 2 CDMA Headphone Jack Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: adım 1, 3 resimden 1. iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: adım 1, 3 resimden 2. iPad 2 CDMA Headphone Jack Assembly Replacement, Headphone Jack Assembly: adım 1, 3 resimden 3.
    • Use the flat end of a plastic opening tool to flip up the retaining flap on the headphone jack and front-facing camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Run a plastic opening tool underneath the headphone jack and front-facing camera cable to free it from the adhesive attaching the cable to the rear panel.
    • Pull the headphone jack and front-facing camera ribbon cable straight out of its socket on the logic board.
  2. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the rear panel.
  3. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to help pull the headphone jack away from its recess in the top edge of the iPad.
    • Don't try to remove the assembly just yet.
  4. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 4, 1 resimden 1.
    • Carefully peel the front camera and microphone cables off the rear panel.
  5. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 5, 2 resimden 1. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 5, 2 resimden 2.
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use the edge of a plastic opening tool to disconnect the front camera cable from the headphone jack cable.
  6. iPad 2 CDMA Headphone Jack Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully peel the front camera cable off the bottom ribbon cable attached to the headphone jack.
Sonuç
Phillip Takahashi
86.686 İtibar
87 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 421
