Ana içeriğe geç
iPad 2 GSM Volume and Power Button Cable Replacement
Neye ihtiyacın var
    1. iPad 2 GSM Volume and Power Button Cable Replacement, iOpener Heating: adım 1, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement, iOpener Heating: adım 1, 2 resimden 2.
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 2, 1 resimden 1.
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      FixBot'a Sor
      Yorum Ekle
    3. iPad 2 GSM Volume and Power Button Cable Replacement: adım 3, 1 resimden 1.
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      FixBot'a Sor
      Yorum Ekle
    4. iPad 2 GSM Volume and Power Button Cable Replacement, Alternate iOpener heating method: adım 4, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement, Alternate iOpener heating method: adım 4, 2 resimden 2.
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      FixBot'a Sor
      Yorum Ekle
    1. iPad 2 GSM Volume and Power Button Cable Replacement, Front Panel: adım 5, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement, Front Panel: adım 5, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement, Front Panel: adım 5, 3 resimden 3.
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 6, 1 resimden 1.
      • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
      • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
      • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
      FixBot'a Sor
      Yorum Ekle
    3. iPad 2 GSM Volume and Power Button Cable Replacement: adım 7, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 7, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 7, 3 resimden 3.
      • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
      • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
      • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
      FixBot'a Sor
      Yorum Ekle
    4. iPad 2 GSM Volume and Power Button Cable Replacement: adım 8, 1 resimden 1.
      • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
      FixBot'a Sor
      Yorum Ekle
    5. iPad 2 GSM Volume and Power Button Cable Replacement: adım 9, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 9, 2 resimden 2.
      • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    6. iPad 2 GSM Volume and Power Button Cable Replacement: adım 10, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 10, 2 resimden 2.
      • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
      FixBot'a Sor
      Yorum Ekle
    7. iPad 2 GSM Volume and Power Button Cable Replacement: adım 11, 1 resimden 1.
      • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
      FixBot'a Sor
      Yorum Ekle
    8. iPad 2 GSM Volume and Power Button Cable Replacement: adım 12, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 12, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 12, 3 resimden 3.
      • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
      • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
      • The adhesive is very strong, and some serious force may be required. Work carefully.
      • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
      FixBot'a Sor
      Yorum Ekle
    9. iPad 2 GSM Volume and Power Button Cable Replacement: adım 13, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 13, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 13, 3 resimden 3.
      • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
      FixBot'a Sor
      Yorum Ekle
    10. iPad 2 GSM Volume and Power Button Cable Replacement: adım 14, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 14, 2 resimden 2.
      • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
      • Re-heat the iOpener, and move it to the top edge of the iPad.
      FixBot'a Sor
      Yorum Ekle
    11. iPad 2 GSM Volume and Power Button Cable Replacement: adım 15, 1 resimden 1.
      • The next few steps require extreme caution.
      • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
      • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
      FixBot'a Sor
      Yorum Ekle
    12. iPad 2 GSM Volume and Power Button Cable Replacement: adım 16, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 16, 2 resimden 2.
      • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
      • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
      FixBot'a Sor
      Yorum Ekle
    13. iPad 2 GSM Volume and Power Button Cable Replacement: adım 17, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 17, 2 resimden 2.
      • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
      • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
      • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
      FixBot'a Sor
      Yorum Ekle
    14. iPad 2 GSM Volume and Power Button Cable Replacement: adım 18, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 18, 2 resimden 2.
      • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
      • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
      • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
      FixBot'a Sor
      Yorum Ekle
    15. iPad 2 GSM Volume and Power Button Cable Replacement: adım 19, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 19, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 19, 3 resimden 3.
      • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
      • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
      • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
      FixBot'a Sor
      Yorum Ekle
    16. iPad 2 GSM Volume and Power Button Cable Replacement: adım 20, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 20, 2 resimden 2.
      • Continue releasing the adhesive all the way along the bottom edge of the iPad.
      • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
      • Leave the opening pick wedged underneath the front glass near the home button.
      FixBot'a Sor
      Yorum Ekle
    17. iPad 2 GSM Volume and Power Button Cable Replacement: adım 21, 1 resimden 1.
      • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
      FixBot'a Sor
      Yorum Ekle
    18. iPad 2 GSM Volume and Power Button Cable Replacement: adım 22, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 22, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 22, 3 resimden 3.
      • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
      • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
      • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
      • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
      FixBot'a Sor
      Yorum Ekle
    19. iPad 2 GSM Volume and Power Button Cable Replacement: adım 23, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 23, 2 resimden 2.
      • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
      • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
      FixBot'a Sor
      Yorum Ekle
    20. iPad 2 GSM Volume and Power Button Cable Replacement: adım 24, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 24, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 24, 3 resimden 3.
      • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
      • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
      FixBot'a Sor
      Yorum Ekle
    21. iPad 2 GSM Volume and Power Button Cable Replacement: adım 25, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 25, 2 resimden 2.
      • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
      • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
      FixBot'a Sor
      Yorum Ekle
    22. iPad 2 GSM Volume and Power Button Cable Replacement: adım 26, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 26, 2 resimden 2.
      • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
      • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
      FixBot'a Sor
      Yorum Ekle
    23. iPad 2 GSM Volume and Power Button Cable Replacement: adım 27, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 27, 2 resimden 2.
      Bu adımda kullanılan alet:
      Microfiber Cleaning Cloths
      $3.99
      • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
      • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
      • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
      FixBot'a Sor
      Yorum Ekle
    1. iPad 2 GSM Volume and Power Button Cable Replacement, LCD: adım 28, 1 resimden 1.
      • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 29, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 29, 2 resimden 2.
      • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
      • Lay the LCD on the front panel as seen in the second picture.
      FixBot'a Sor
      Yorum Ekle
    1. iPad 2 GSM Volume and Power Button Cable Replacement, Rear Camera: adım 30, 1 resimden 1.
      • Carefully peel the rubber cover off the metal camera retainer and remove it from the iPad 2.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 31, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 31, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 31, 3 resimden 3.
      • Remove the following two screws:
      • One 3.3 mm Phillips screw
      • One 2.1 mm Phillips screw
      • Lift the metal retainer clip straight up from its recess in the rear panel.
      • If the camera comes up with the retaining clip, don't worry. Just separate the camera from the clip before reinstalling, so you can be sure to get the connector in the right place.
      • Be sure the small thermal pad is attached to the metal retaining clip as seen in the third picture when replacing the rear camera.
      FixBot'a Sor
      Yorum Ekle
    3. iPad 2 GSM Volume and Power Button Cable Replacement: adım 32, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 32, 2 resimden 2.
      • Use a plastic opening tool to pry the rear camera connector up from its socket on the upper component board.
      • Remove the rear camera.
      FixBot'a Sor
      Yorum Ekle
    1. iPad 2 GSM Volume and Power Button Cable Replacement, Volume and Power Button Cable: adım 33, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement, Volume and Power Button Cable: adım 33, 2 resimden 2.
      • Remove any foam tape from the top of the GPS cable ZIF connector.
      • Use the tip of a spudger to flip the retaining tab on the ZIF connector to release the GPS cable.
      • Do not attempt to disconnect this cable yet—it will come free when you remove the upper component board.
      FixBot'a Sor
      Yorum Ekle
    2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 34, 1 resimden 1.
      • Remove the following screws from the volume/power button assembly cable:
      • Two 2.5 mm Phillips #000 screws, at a 45º angle securing the power button.
      • Two 5 mm Phillips #000 screws
      • One 2 mm Phillips #000 screw at a 45º angle.
      FixBot'a Sor
      Yorum Ekle
    3. iPad 2 GSM Volume and Power Button Cable Replacement: adım 35, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 35, 2 resimden 2.
      • Remove the metal bracket securing the rotation lock/silent switch.
      FixBot'a Sor
      Yorum Ekle
    4. iPad 2 GSM Volume and Power Button Cable Replacement: adım 36, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 36, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 36, 3 resimden 3.
      • Pull the power button cable out of the recess in the rear case and bend it out of the way.
      • The ribbon cable contains the mechanical button that needs to mate with the plastic button cover that remains in the case.
      FixBot'a Sor
      Yorum Ekle
    5. iPad 2 GSM Volume and Power Button Cable Replacement: adım 37, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 37, 2 resimden 2.
      • Remove the sleep/power button form the rear case.
      • Note the orientation for reassembly; the metal spring bar should fall down toward the rear of the case.
      FixBot'a Sor
      Yorum Ekle
    6. iPad 2 GSM Volume and Power Button Cable Replacement: adım 38, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 38, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 38, 3 resimden 3.
      • Use the center screw hole of the volume control bracket to tilt it out toward the edge of the case and then pull it up out of its recess.
      • Do not remove the bracket entirely as it is still attached to the button ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    7. iPad 2 GSM Volume and Power Button Cable Replacement: adım 39, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 39, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 39, 3 resimden 3.
      • Gently peel the power and volume button cable away from the rear case.
      • Bend the cable toward the inside of the rear case, but do not attempt to remove it as it is still connected to the upper component board.
      FixBot'a Sor
      Yorum Ekle
    8. iPad 2 GSM Volume and Power Button Cable Replacement: adım 40, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 40, 2 resimden 2.
      • Remove the rotation lock/silent switch from the rear case.
      • Note the orientation for reassembly. The mechanical switch will also need to mate with this button cover; ensure that they properly interlock.
      FixBot'a Sor
      Yorum Ekle
    9. iPad 2 GSM Volume and Power Button Cable Replacement: adım 41, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 41, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 41, 3 resimden 3.
      • Use the tip of a spudger to push the volume rocker into the interior of the rear case.
      • Remove the volume rocker from the rear case.
      FixBot'a Sor
      Yorum Ekle
    10. iPad 2 GSM Volume and Power Button Cable Replacement: adım 42, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 42, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 42, 3 resimden 3.
      • Use the point of an opening pick to gently peel the Smart Cover sleep/wake sensor up off the rear case.
      FixBot'a Sor
      Yorum Ekle
    11. iPad 2 GSM Volume and Power Button Cable Replacement: adım 43, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 43, 2 resimden 2.
      • Carefully peel the volume rocker portion of the button cable away from the rear case.
      FixBot'a Sor
      Yorum Ekle
    12. iPad 2 GSM Volume and Power Button Cable Replacement: adım 44, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 44, 2 resimden 2.
      • Gently peel the last horizontal portion off of the rear case.
      • Do not remove the cable entirely, the cable is still attached by a connector taped to the upper component board.
      FixBot'a Sor
      Yorum Ekle
    13. iPad 2 GSM Volume and Power Button Cable Replacement: adım 45, 1 resimden 1.
      • Remove the single 2 mm Phillips #000 screw from the lower end of the upper component board.
      FixBot'a Sor
      Yorum Ekle
    14. iPad 2 GSM Volume and Power Button Cable Replacement: adım 46, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 46, 2 resimden 2.
      • Use a set of tweezers to remove the foam block from between the rear case and the upper component board.
      FixBot'a Sor
      Yorum Ekle
    15. iPad 2 GSM Volume and Power Button Cable Replacement: adım 47, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 47, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 47, 3 resimden 3.
      • Insert a spudger under the end of the upper component board and gently slide it toward the volume rocker to free the board from adhesive.
      • Be very careful not to bend the board too much or scrape it against the top of the rear case.
      FixBot'a Sor
      Yorum Ekle
    16. iPad 2 GSM Volume and Power Button Cable Replacement: adım 48, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 48, 2 resimden 2.
      • Insert a spudger under the GPS connector end of the upper component board and lift it up off of its adhesive.
      • Be very careful not to scrape the board against the top of the rear case.
      • The GPS antenna cable will slide out of its ZIF socket when you do this. On reassembly, fit the cable back into the socket as you replace the upper component board.
      FixBot'a Sor
      Yorum Ekle
    17. iPad 2 GSM Volume and Power Button Cable Replacement: adım 49, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 49, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 49, 3 resimden 3.
      • Flip up the retaining bar securing the upper component board cable connector.
      • Pull the connector straight out of its socket on the logic board.
      • Do not lift the cable upward as you disconnect it.
      FixBot'a Sor
      Yorum Ekle
    18. iPad 2 GSM Volume and Power Button Cable Replacement: adım 50, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 50, 2 resimden 2.
      • Lift the end of the upper component board cable up off of the adhesive holding it to the rear case.
      FixBot'a Sor
      Yorum Ekle
    19. iPad 2 GSM Volume and Power Button Cable Replacement: adım 51, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 51, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 51, 3 resimden 3.
      • To remove the upper component board you will be pulling gently on its cable while lifting it up enough to clear the battery, but not high enough to scrape against the rear case. Go slowly and carefully.
      • Insert the tip of a spudger under the upper component board to lift it slightly.
      • Pull the board up and out of the space between the battery and the rear case bezel.
      • Remove the upper component board.
      • On reassembly, you'll want to reconnect the GPS antenna cable at this point. Use tweezers and work carefully.
      FixBot'a Sor
      Yorum Ekle
    20. iPad 2 GSM Volume and Power Button Cable Replacement: adım 52, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 52, 2 resimden 2.
      • Peel the tape covering the button cable connector off of the upper component board.
      FixBot'a Sor
      Yorum Ekle
    21. iPad 2 GSM Volume and Power Button Cable Replacement: adım 53, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 53, 2 resimden 2.
      • Lift the button cable connector straight up off of its connector on the upper component board.
      FixBot'a Sor
      Yorum Ekle
    22. iPad 2 GSM Volume and Power Button Cable Replacement: adım 54, 2 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 54, 2 resimden 2.
      • If your replacement part comes with the metal button brackets attached, you can skip the following steps.
      • Peel the power button off of the power button bracket.
      • Note the orientation and adhesive placement for reassembly.
      FixBot'a Sor
      Yorum Ekle
    23. iPad 2 GSM Volume and Power Button Cable Replacement: adım 55, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 55, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 55, 3 resimden 3.
      • Insert the point of an opening pick between the rotation lock/silent switch and its bracket to sever the adhesive there.
      FixBot'a Sor
      Yorum Ekle
    24. iPad 2 GSM Volume and Power Button Cable Replacement: adım 56, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 56, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 56, 3 resimden 3.
      • Slide the opening pick under the remaining portion of the rotation lock/silent switch to peel it up off the button bracket.
      FixBot'a Sor
      Yorum Ekle
    25. iPad 2 GSM Volume and Power Button Cable Replacement: adım 57, 3 resimden 1. iPad 2 GSM Volume and Power Button Cable Replacement: adım 57, 3 resimden 2. iPad 2 GSM Volume and Power Button Cable Replacement: adım 57, 3 resimden 3.
      • Use the point of the opening pick to peel the mechanical volume buttons up from the bracket.
      • Remove the button cable assembly from the button bracket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
51 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.931 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
71.524 adet Kılavuz yazıldı
5Kılavuz Yorumları
Great guide!!!! It was hard but great details!!!
apriltanner1975 - Yanıt Paylaş
i replaced this cable and now the screen went to dim to no pic please help
ian bronson - Yanıt Paylaş
I would rather gouge my eyes out with a wooden spoon than ever have to do this repair again! It was the hardest repair I have ever done!! I will never rip another power button flex cable again
mamashannon4u - Yanıt Paylaş
Your guide is really well done! I was able to retrieve the broken cable without trouble on my first try, but putting it back together was the most annoying part.
Sarai - Yanıt Paylaş
Did you find a guide on how to put it back apart again? That’s where I’m stuck at :(
Jessica - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 59,150
