Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the adhesive on your iPad 3 4G to seal the deal on a repair job well done.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
It is recommended that you peel each adhesive strip as needed, rather than lay them out all at once.
Neye ihtiyacın var
Carefully grasp the home button with a pair of tweezers.
Gently lower and place the home button into the round opening located at the bottom of the front panel.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Need to update this instruction because the new adhesive strips I used for my iPad3 4G repair was different than what is shown in this guide. Granted, it’s pretty easy to figure out.
