Giriş
If you have damaged your display bezel, you can use this guide to help you replace it.
The display bezel guide was initially created for the iPad 3 Wi-Fi. However, the procedure for removing the display bezel is identical for both the 4G and Wi-Fi models.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
Using the tip of a spudger, peel back the piece of tape that secures the touchscreen ribbon cable to the logic board.
Insert the edge of plastic opening tool between the plastic and aluminum frames near one of the corners.
Carefully slide the plastic opening tool along the edge of the iPad, releasing the adhesive.
23 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hi, I'm getting ready to replace my screen, but the bezel is missing from the kit. Can I still replace my ipad 3 (wifi only) screen without it? The adhesive strips were included.
ipad 3 digitizer replacement from white bezel to black bezel. Is it possible? Any incompatibility issues?
