Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iPad 6 Wi-Fi Front Panel Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 2.
    • Remove any tape covering the home button ribbon cable connector.
  2. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 2, 3 resimden 1. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 2, 3 resimden 2. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 2, 3 resimden 3.
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  3. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 3, 3 resimden 1. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 3, 3 resimden 2. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 3, 3 resimden 3.
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  4. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 4, 2 resimden 1. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 4, 2 resimden 2.
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  5. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 5, 2 resimden 1. iPad 6 Wi-Fi Front Panel Assembly Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Polyimide Tape
    $9.99
    Satın Al
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Goldheart
465.777 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 132
