Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. iPad ClamCase cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPad ClamCase, iPad ClamCase: adım 1, 2 resimden 1. iPad ClamCase, iPad ClamCase: adım 1, 2 resimden 2.
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
    FixBot'a Sor
    Yorum Ekle
  2. iPad ClamCase: adım 2, 2 resimden 1. iPad ClamCase: adım 2, 2 resimden 2.
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
    FixBot'a Sor
    Yorum Ekle
  3. iPad ClamCase: adım 3, 2 resimden 1. iPad ClamCase: adım 3, 2 resimden 2.
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
    FixBot'a Sor
    Yorum Ekle
  4. iPad ClamCase: adım 4, 1 resimden 1.
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
    FixBot'a Sor
    Yorum Ekle
  5. iPad ClamCase: adım 5, 1 resimden 1.
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
    FixBot'a Sor
    Yorum Ekle
  6. iPad ClamCase: adım 6, 1 resimden 1.
    • You are done.
    FixBot'a Sor
    Yorum Ekle
Izmet Barranco
213 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Yanıt Paylaş
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 8,207
