Ana içeriğe geç
iPad Mini Home button Replacement
Neye ihtiyacın var
  1. iPad Mini Home button Replacement, Reveal solder pads: adım 1, 1 resimden 1.
    • Use heat to losen the adhesive. A low temp hot air gun will suffice.
    • After heating up the adhesive, you can use a basic spudger to pry off the flex from the glass
    • be sure not to use too much force, this flex is very fragile.
    FixBot'a Sor
    Yorum Ekle
  2. iPad Mini Home button Replacement, Apply your own solder: adım 2, 1 resimden 1.
    • use your iron, and low guage solder to apply a layer of your own solder on the pads
    • the new solder will allow for faster, and more controlled heat transfer.
    FixBot'a Sor
    Yorum Ekle
  3. iPad Mini Home button Replacement, Remove the flex: adım 3, 1 resimden 1.
    • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
    • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
    • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
    FixBot'a Sor
    Yorum Ekle
  4. iPad Mini Home button Replacement, Line up the pads: adım 4, 1 resimden 1.
    • be sure to make sure you can see directly through the holes marked on both sides.
    • Line the corrisponding holes up, and make sure they are 100% overlapped.
    • failing to properly line up the holes can cause a short, or cold circuit.
    FixBot'a Sor
    Yorum Ekle
  5. iPad Mini Home button Replacement, Re-Solder: adım 5, 1 resimden 1.
    • Use the new solder you added, to connect to the flex.
    • be sure to cover the traces with some electrical tape to avoid shorts.
    • congratulations on your home button replacement
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Scott
9.937 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 71
Her zaman: 13,157
