Ana içeriğe geç
iPad Wi-Fi Front Panel Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: adım 1, 3 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: adım 1, 3 resimden 2. iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
    2) If so,will the tape take the display’s oleophobic coating with it when removed?
    Mitch Stary - Yanıt
    Hola necesito comprar
    Alsone Michel - Yanıt
    Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
    iPad LCD Panel
    Safety Glasses
    Sandra Hiller -
  2. iPad Wi-Fi Front Panel Assembly Replacement: adım 2, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 2, 2 resimden 2.
    • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
    • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
    • If you do happen to break some clips, you can buy replacements here.
    A clearer explanation of the orientation is needed here. The bar code is at the top left of the iPad when you are looking at the screen.
    David Hincks - Yanıt
  3. iPad Wi-Fi Front Panel Assembly Replacement: adım 3, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 3, 2 resimden 2.
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    Tip* "ONLY WITH METAL SPUDGER* heat it with a lighter till its warm to touch, then slide it like a butter knife. it reduces chances of chipping glass.
    luckie - Yanıt
    I've found that by using a thicker iPad tool dents the back less(not at all if your careful) and start prying just under the volume button and working my way down works better as the metal clips are on all sider except the right side.
    richard - Yanıt
    It would be really helpful to point out where all the clips and tabs are, and to show a picture of them (unbroken), so you know what you're trying to release.
    Styg - Yanıt
  4. iPad Wi-Fi Front Panel Assembly Replacement: adım 4, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 4, 2 resimden 2.
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
    Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
    richard - Yanıt
  5. iPad Wi-Fi Front Panel Assembly Replacement: adım 5, 1 resimden 1.
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
    By it's BOTTOM edge.
    jonathan - Yanıt
  6. iPad Wi-Fi Front Panel Assembly Replacement: adım 6, 1 resimden 1.
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
  7. iPad Wi-Fi Front Panel Assembly Replacement: adım 7, 3 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 7, 3 resimden 2. iPad Wi-Fi Front Panel Assembly Replacement: adım 7, 3 resimden 3.
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    Adding this comment in its proper place:
    After flipping up the metal retainer, pull it sideways.
    Do not pull it up vertically.
    Joe in PA
  8. iPad Wi-Fi Front Panel Assembly Replacement: adım 8, 1 resimden 1.
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  9. iPad Wi-Fi Front Panel Assembly Replacement: adım 9, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 9, 2 resimden 2.
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
    Roger Buttermore - Yanıt
  10. iPad Wi-Fi Front Panel Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the display assembly from the rear panel assembly.
  11. iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: adım 11, 3 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: adım 11, 3 resimden 2. iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: adım 11, 3 resimden 3.
    • If you are reusing the LCD, it is not necessary to peel the ambient light sensor off the back face of the LCD.
    • Use the edge of a plastic opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
    • Once you've gained enough clearance, peel the ambient light sensor off the LCD.
    • Be careful not to crease the ambient light sensor below its top section, as the portion with adhesive applied may break off.
    • If necessary, attach the plastic view window to your new ambient light sensor before installation.
    You can leave the sensor stuck to the LCD if you're reusing the LCD. It just stays attached to the LCD no problem.
    jonathan - Yanıt
    Step 7 after flipping up the metal retainer, pull it sideways.
    Joe in PA - Yanıt
    I added your comment in the proper place at Step 7
    David Hincks -
  12. iPad Wi-Fi Front Panel Assembly Replacement, LCD: adım 12, 1 resimden 1.
    • While holding the digitizer cable down, carefully peel back the piece of tape connecting the digitizer cable to the display frame.
  13. iPad Wi-Fi Front Panel Assembly Replacement: adım 13, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 13, 2 resimden 2.
    • Remove the three T5 Torx screws securing the clips and LCD brackets covered in EMI tape near the home button switch.
    • Carefully peel the display clip and its attached tape off the black plastic display frame.
    • If you are replacing the LCD, be sure to transfer these pieces of EMI tape and their attached clips to the new LCD.
  14. iPad Wi-Fi Front Panel Assembly Replacement: adım 14, 1 resimden 1.
    • Remove the remaining T5 Torx screws securing the LCD to the black plastic display frame.
    I see that the author broke 4 tabs on the top and 2 tabs on the bottom -- the exact same ones that I broke. I must be following his instructions perfectly!
    Styg - Yanıt
  15. iPad Wi-Fi Front Panel Assembly Replacement: adım 15, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 15, 2 resimden 2.
    • Insert the edge of a plastic opening tool under one of the ears attached to the steel LCD frame.
    • Twist the plastic opening tool to gently pry the LCD up off the adhesive securing it to the front glass panel.
    • Be sure not to excessively bend the LCD, as it is made of glass.
  16. iPad Wi-Fi Front Panel Assembly Replacement: adım 16, 1 resimden 1.
    • Repeat the process detailed on the previous step to pry up the display around the three sides opposite the digitizer cable side of the display.
  17. iPad Wi-Fi Front Panel Assembly Replacement: adım 17, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 17, 2 resimden 2.
    • Lift the LCD from its free end, and remove it from the display frame.
    • Carefully peel the adhesive securing the long side of the LCD to the display frame, then remove the LCD.
    remove the home button spring assembly from the old digitizer and transfer it to the new one!!!!!!!!!
    wh1513 - Yanıt
  18. iPad Wi-Fi Front Panel Assembly Replacement: adım 18, 1 resimden 1.
    • If it is still stuck to the front panel, remove the strip of EMI tape near the ambient light sensor socket.
    • If necessary, transfer this to your new LCD.
    • If it is attached to the LCD and you are reusing the LCD, skip this step. If you are replacing the LCD as well, transfer the strip of EMI tape to your new LCD.
    Jeez!! Please put to keep the emi tape if you are resusing your lcd BEFORE the step that says to remove it...I don't know how import this stuff is, but I'm guessing pretty important cause I just removed it.
    Noah - Yanıt
  19. iPad Wi-Fi Front Panel Assembly Replacement: adım 19, 1 resimden 1.
    • If they are still in good shape, transfer the clips and EMI tape near the bottom of the LCD to your new LCD.
  20. iPad Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: adım 20, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: adım 20, 2 resimden 2.
    • Remove the two T5 Torx screws securing the home button switch to the plastic display frame.
    • Remove the home button switch board from the front panel assembly.
  21. iPad Wi-Fi Front Panel Assembly Replacement: adım 21, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 21, 2 resimden 2.
    • If you are reusing your LCD, use the edge of a plastic opening tool to lift up a corner of the foam tape attached to the LCD.
    • Remove the tape from the perimeter of the glass face of the LCD.
  22. iPad Wi-Fi Front Panel Assembly Replacement: adım 22, 2 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 22, 2 resimden 2.
    • Remove the piece of yellow tape securing the digitizer cable to the inner face of the front panel assembly, being careful not to rip the cable in the process.
    • Peel the protective sheeting off the inner face of the front panel assembly.
    • Be careful not to get any fingerprints or dust on the inner face of the front panel, as they will be annoyingly visible when the device is turned on.
  23. iPad Wi-Fi Front Panel Assembly Replacement: adım 23, 1 resimden 1.
    • Be sure the face of the LCD is perfectly clean before proceeding.
    • Stick the tape down along the long edge of the LCD to the frame of the front panel assembly.
    • Carefully lower the LCD down into its recess in the front panel frame, being sure it is properly positioned.
  24. iPad Wi-Fi Front Panel Assembly Replacement: adım 24, 3 resimden 1. iPad Wi-Fi Front Panel Assembly Replacement: adım 24, 3 resimden 2. iPad Wi-Fi Front Panel Assembly Replacement: adım 24, 3 resimden 3.
    • Hold back the strips of EMI tape along the lower edge of the LCD as you remove the two T5 Torx screws securing the retaining clips shown.
    • Stick the tape down against the new clips and reinstall the two T5 Torx screws.
    • If you are replacing your panel with a new one, be aware that the new panel may have a protective film on the outside and/or inside of the frame. This needs to be removed.
Sonuç
Continue the installation by following the guide from Step 12 in reverse.
44 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
LCD cable is easily trapped under lcd on reassembly without due care causing colour differences on snapping into place
scott corbett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 59,452
