Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace a non-functioning home button switch.
Neye ihtiyacın var
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Remove the two T5 Torx screws securing the home button switch board to the display frame.
9 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If you prefer to watch a video of disassembly/reassembly for the home button diagnostics, I have successfully completed the whole process ;) You can see it here:
Apple iPad 1st Gen Home Button Malfunction - disassembly & repair (https://www.youtube.com/watch?v=lYwuIyFI...)
Even though I had a replacement home button board ready, it wasn't needed. Sometimes you just need to clean up contact pads and/or make sure that spring-loaded pins are not stuck. This unfortunately still requires screen removal, which means that some of the screen clips are going to break, that's just how it is :(
