Ana içeriğe geç
iPad Wi-Fi LCD Replacement
Neye ihtiyacın var
  1. iPad Wi-Fi LCD Replacement, Display Assembly: adım 1, 3 resimden 1. iPad Wi-Fi LCD Replacement, Display Assembly: adım 1, 3 resimden 2. iPad Wi-Fi LCD Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  2. iPad Wi-Fi LCD Replacement: adım 2, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 2, 2 resimden 2.
    • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
    • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
    • If you do happen to break some clips, you can buy replacements here.
    FixBot'a Sor
    Yorum Ekle
  3. iPad Wi-Fi LCD Replacement: adım 3, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 3, 2 resimden 2.
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    FixBot'a Sor
    Yorum Ekle
  4. iPad Wi-Fi LCD Replacement: adım 4, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 4, 2 resimden 2.
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
    FixBot'a Sor
    Yorum Ekle
  5. iPad Wi-Fi LCD Replacement: adım 5, 1 resimden 1.
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
    FixBot'a Sor
    Yorum Ekle
  6. iPad Wi-Fi LCD Replacement: adım 6, 1 resimden 1.
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    FixBot'a Sor
    Yorum Ekle
  7. iPad Wi-Fi LCD Replacement: adım 7, 3 resimden 1. iPad Wi-Fi LCD Replacement: adım 7, 3 resimden 2. iPad Wi-Fi LCD Replacement: adım 7, 3 resimden 3.
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    FixBot'a Sor
    Yorum Ekle
  8. iPad Wi-Fi LCD Replacement: adım 8, 1 resimden 1.
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
    FixBot'a Sor
    Yorum Ekle
  9. iPad Wi-Fi LCD Replacement: adım 9, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 9, 2 resimden 2.
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    FixBot'a Sor
    Yorum Ekle
  10. iPad Wi-Fi LCD Replacement: adım 10, 1 resimden 1.
    • Remove the display assembly from the rear panel assembly.
    FixBot'a Sor
    Yorum Ekle
  11. iPad Wi-Fi LCD Replacement, Ambient Light Sensor: adım 11, 3 resimden 1. iPad Wi-Fi LCD Replacement, Ambient Light Sensor: adım 11, 3 resimden 2. iPad Wi-Fi LCD Replacement, Ambient Light Sensor: adım 11, 3 resimden 3.
    • If you are reusing the LCD, it is not necessary to peel the ambient light sensor off the back face of the LCD.
    • Use the edge of a plastic opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
    • Once you've gained enough clearance, peel the ambient light sensor off the LCD.
    • Be careful not to crease the ambient light sensor below its top section, as the portion with adhesive applied may break off.
    • If necessary, attach the plastic view window to your new ambient light sensor before installation.
    FixBot'a Sor
    Yorum Ekle
  12. iPad Wi-Fi LCD Replacement, LCD: adım 12, 1 resimden 1.
    • While holding the digitizer cable down, carefully peel back the piece of tape connecting the digitizer cable to the display frame.
    FixBot'a Sor
    Yorum Ekle
  13. iPad Wi-Fi LCD Replacement: adım 13, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 13, 2 resimden 2.
    • Remove the three T5 Torx screws securing the clips and LCD brackets covered in EMI tape near the home button switch.
    • Carefully peel the display clip and its attached tape off the black plastic display frame.
    • If you are replacing the LCD, be sure to transfer these pieces of EMI tape and their attached clips to the new LCD.
    FixBot'a Sor
    Yorum Ekle
  14. iPad Wi-Fi LCD Replacement: adım 14, 1 resimden 1.
    • Remove the remaining T5 Torx screws securing the LCD to the black plastic display frame.
    FixBot'a Sor
    Yorum Ekle
  15. iPad Wi-Fi LCD Replacement: adım 15, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 15, 2 resimden 2.
    • Insert the edge of a plastic opening tool under one of the ears attached to the steel LCD frame.
    • Twist the plastic opening tool to gently pry the LCD up off the adhesive securing it to the front glass panel.
    • Be sure not to excessively bend the LCD, as it is made of glass.
    FixBot'a Sor
    Yorum Ekle
  16. iPad Wi-Fi LCD Replacement: adım 16, 1 resimden 1.
    • Repeat the process detailed on the previous step to pry up the display around the three sides opposite the digitizer cable side of the display.
    FixBot'a Sor
    Yorum Ekle
  17. iPad Wi-Fi LCD Replacement: adım 17, 2 resimden 1. iPad Wi-Fi LCD Replacement: adım 17, 2 resimden 2.
    • Lift the LCD from its free end, and remove it from the display frame.
    • Carefully peel the adhesive securing the long side of the LCD to the display frame, then remove the LCD.
    FixBot'a Sor
    Yorum Ekle
  18. iPad Wi-Fi LCD Replacement: adım 18, 1 resimden 1.
    • If it is still stuck to the front panel, remove the strip of EMI tape near the ambient light sensor socket.
    • If necessary, transfer this to your new LCD.
    • If it is attached to the LCD and you are reusing the LCD, skip this step. If you are replacing the LCD as well, transfer the strip of EMI tape to your new LCD.
    FixBot'a Sor
    Yorum Ekle
  19. iPad Wi-Fi LCD Replacement: adım 19, 1 resimden 1.
    • If they are still in good shape, transfer the clips and EMI tape near the bottom of the LCD to your new LCD.
    FixBot'a Sor
    Yorum Ekle
Sonuç
79 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
So what if ive snapped off one of the retaining flaps? Ive seen in the past when ive snapped them off before i could just plug it in, slap on some kapton tape and it was fine. This time i cant get the bottom of the digitizer to work on new glass. I put on the old glass and the bottom works just fine. the bottom flap is the one that broke, but why would the old glass work just fine, but the new glass does nothing on the bottom half?
Blib - Yanıt Paylaş
Just replaced my lcd using this guide. Not easy, but doable. Took about an hour and a half. broke about half of the clips that hold the assembly in, but moved the remaining ones around so that it is secure. I recommend buying replacement clips if you aren't comfortable with that. Also, this guide says to use a Torx T5 screwdriver. Other sites say T4. It is most definitely T5. I bought the wrong one first and had to get a new one. Home Depot has an 8 in 1 Torx tool for 6 bucks that is great. Thank you iFixit for saving me hundreds that I would have spent on a new iPad!
dcook88 - Yanıt Paylaş
Don't worry about buying more replacment clips -- if you still have them on the left edge, not having the clips on the top and bottom isn't noticeable.
Styg - Yanıt Paylaş
When reassembling at the last step (inserting the screen assembly into the back cover), do NOT simply do the reverse of what you did to take it out. Instead, insert the right edge first (with the plastic tabs). The metal tabs on the left edge (and top and bottom edges if you have any left) are flexible, so it is very easy to snap the left edge of the screen into the back cover AFTER the right edge is in place. If you put the left edge in first, you'll have a much tougher time trying to get the plastic tabs on the right edge into back cover.
Styg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 35
Son 30 gün: 120
Her zaman: 214,475
