Giriş
Use this guide to remove or replace the two screws securing the iPhone 12 display panel. These are the only screws on the exterior of the iPhone. They use a five-point design that is unique to Apple, requiring a specialty P2 pentalobe driver for removal.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
10 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
why is this a thing
This is perfect, thank you! I wasn’t sure I’d be able to do this repair, but with this expert guidance I have succeeded. I’m ready for level 3.
well done - would you like medal
someone just pointed out the fact it says to discharge the battery -
‘Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. ‘
you are removing the 2 pentalobes, not anything ‘internal’
Do you sell the waterproof seals separately or are they included in the kit?
Heather Furnas - Yanıt
Do you sell the waterproof seals separately or are they included in the kit? (I would like to know this as well.)
CaliforniaGunner - Yanıt
I just got my Fix Kit and it includes the seals. Not sure if a "part only" version would, though.
Neal Sofge - Yanıt
