Giriş
We couldn’t quite fit every last drop of chip ID into our iPhone 13 Pro teardown. So if you’re yearning for more, here is a much more thorough look into the chips found on the iPhone 13 Pro’s logic board.
Special thanks to our community member Chunglin Chin for contributing to this!
Logic board, side 1:
Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
Apple APL1098 power management IC
Apple 338S00762-A1 power management IC
STMicroelectronics STB601A05 power management IC
Apple 338S00770-B0 power management IC
Texas Instruments TPS65657B0 display power management IC
NXP Semiconductor CBTL1616A0 display port multiplexer
Logic board, side 1 (cont.):
Apple/USI U1 ultra-wideband chip
Skyworks SKY58271-19 front-end module
Skyworks SKY58276-17 front-end module
Likely a Broadcom AFEM-8225 front-end module
Likely a Skyworks SKY59723 power amplifier module
Likely a Murata 141 RF switch module
Likely Broadcom filters
Logic board, sides 2 and 3:
128 GB of Kioxia NAND flash memory
STMicroelectronics ST33Jxxx secure microcontroller w/ eSIM
Possibly an Apple/Cirrus Logic 338S00817 audio processor
Apple/Cirrus Logic 338S00739 audio codec
Apple/Cirrus Logic 338S00537 audio amplifier
Broadcom BCM59365 wireless power receiver
Likely an Analog Devices haptic driver
Logic board, sides 2 and 3 (cont.):
Qualcomm PMX60 power management IC
Apple 338S00616 power management IC
Texas Instruments LM3567A1 LED flash driver
ON Semiconductor DC-DC converter
Likely a STMicroelectronics DC-DC converter
Nexperia 74AVC1T45 3-state voltage level translator/transceiver
Nexperia LSF0101 1-bit bidirectional voltage level translator
Bosch Sensortec 6-axis accelerometer/gyroscope
7 Yorum
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
Logic board For IPhone 13 pro
The light blue rectangle is what we would call the charging ic. It is a variant of the earlier Tigris and later Yangtze chips that are commonly damaged by rogue chargers. The function of this chip is to create the main power rail from the battery or charger voltage, and control charging of the battery while on the charger. Due to the lack of public schematics for iPhone 13 series, we'd like to propose calling this chip "Genesee" following the river naming convention. The Genesee river is in Rochester, NY
jessabethany - Yanıt
The purple chip is a new generation of the usb port communication hub. In earlier models this is the famous tristar chip, later called hydra in the iPhone 8 and then Kraken in iPhone 11.
