Ana içeriğe geç
iPhone 13 mini Pentalobe Screws Replacement
Neye ihtiyacın var
  1. iPhone 13 mini Pentalobe Screws Replacement, Remove the screws: adım 1, 2 resimden 1. iPhone 13 mini Pentalobe Screws Replacement, Remove the screws: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
48.052 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.732 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 29
Son 30 gün: 100
Her zaman: 2,217
