Ana içeriğe geç
iPhone 15 Back Glass Removal
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 15 Back Glass Removal, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 15 Back Glass Removal, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Back Glass Removal, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Back Glass Removal, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Back Glass Removal, Remove the pentalobe screws: adım 3, 2 resimden 1. iPhone 15 Back Glass Removal, Remove the pentalobe screws: adım 3, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 15 Back Glass Removal, Heat the bottom edge: adım 4, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  5. iPhone 15 Back Glass Removal, Insert an opening pick: adım 5, 3 resimden 1. iPhone 15 Back Glass Removal, Insert an opening pick: adım 5, 3 resimden 2. iPhone 15 Back Glass Removal, Insert an opening pick: adım 5, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  6. iPhone 15 Back Glass Removal, Back glass information: adım 6, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  7. iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: adım 7, 3 resimden 1. iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: adım 7, 3 resimden 2. iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: adım 7, 3 resimden 3.
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  8. iPhone 15 Back Glass Removal, Heat the right edge: adım 8, 1 resimden 1.
    • Heat the right edge of the back glass until it's hot to the touch.
  9. iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: adım 9, 3 resimden 1. iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: adım 9, 3 resimden 2. iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: adım 9, 3 resimden 3.
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. iPhone 15 Back Glass Removal, Heat the left edge: adım 10, 1 resimden 1.
    • Heat the left edge of the back glass until it's hot to the touch.
  11. iPhone 15 Back Glass Removal, Separate the left edge adhesive: adım 11, 3 resimden 1. iPhone 15 Back Glass Removal, Separate the left edge adhesive: adım 11, 3 resimden 2. iPhone 15 Back Glass Removal, Separate the left edge adhesive: adım 11, 3 resimden 3.
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  12. iPhone 15 Back Glass Removal, Heat the top edge: adım 12, 1 resimden 1.
    • Heat the top edge of the back glass until it's hot to the touch.
  13. iPhone 15 Back Glass Removal, Separate the top edge adhesive: adım 13, 3 resimden 1. iPhone 15 Back Glass Removal, Separate the top edge adhesive: adım 13, 3 resimden 2. iPhone 15 Back Glass Removal, Separate the top edge adhesive: adım 13, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  14. iPhone 15 Back Glass Removal, Heat the top right corner: adım 14, 1 resimden 1.
    • Heat the top right corner of the back glass until it's hot to the touch.
  15. iPhone 15 Back Glass Removal, Separate the top right corner adhesive: adım 15, 3 resimden 1. iPhone 15 Back Glass Removal, Separate the top right corner adhesive: adım 15, 3 resimden 2. iPhone 15 Back Glass Removal, Separate the top right corner adhesive: adım 15, 3 resimden 3.
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  16. iPhone 15 Back Glass Removal, Swing open the back glass: adım 16, 3 resimden 1. iPhone 15 Back Glass Removal, Swing open the back glass: adım 16, 3 resimden 2. iPhone 15 Back Glass Removal, Swing open the back glass: adım 16, 3 resimden 3.
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
Sonuç
Clay Eickemeyer
99.360 İtibar
471 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
16.366 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 146
