Ana içeriğe geç
iPhone 15 Plus Battery Disconnection
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 15 Plus Battery Disconnection, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 15 Plus Battery Disconnection, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Battery Disconnection, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Plus Battery Disconnection, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Battery Disconnection, Mark your opening picks: adım 3, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Mark your opening picks: adım 3, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Plus Battery Disconnection, Remove the pentalobe screws: adım 4, 1 resimden 1.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Battery Disconnection, Heat the bottom edge: adım 5, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Battery Disconnection, Insert an opening pick: adım 6, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Insert an opening pick: adım 6, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Battery Disconnection, Back glass information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Plus Battery Disconnection, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Battery Disconnection, Heat the right edge: adım 9, 1 resimden 1.
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Plus Battery Disconnection, Separate the bottom right corner adhesive: adım 10, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Separate the bottom right corner adhesive: adım 10, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Separate the bottom right corner adhesive: adım 10, 3 resimden 3.
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Plus Battery Disconnection, Heat the left edge: adım 11, 1 resimden 1.
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Plus Battery Disconnection, Separate the left edge adhesive: adım 12, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Separate the left edge adhesive: adım 12, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Separate the left edge adhesive: adım 12, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Plus Battery Disconnection, Heat the top edge: adım 13, 1 resimden 1.
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Plus Battery Disconnection, Separate the top edge adhesive: adım 14, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Separate the top edge adhesive: adım 14, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Separate the top edge adhesive: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Plus Battery Disconnection, Heat the top right corner: adım 15, 1 resimden 1.
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Plus Battery Disconnection, Separate the top right corner adhesive: adım 16, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Separate the top right corner adhesive: adım 16, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Separate the top right corner adhesive: adım 16, 3 resimden 3.
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Plus Battery Disconnection, Swing open the back glass: adım 17, 2 resimden 1. iPhone 15 Plus Battery Disconnection, Swing open the back glass: adım 17, 2 resimden 2.
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Plus Battery Disconnection, Unfasten the lower connector cover: adım 18, 2 resimden 1. iPhone 15 Plus Battery Disconnection, Unfasten the lower connector cover: adım 18, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Plus Battery Disconnection, Remove the lower connector cover: adım 19, 3 resimden 1. iPhone 15 Plus Battery Disconnection, Remove the lower connector cover: adım 19, 3 resimden 2. iPhone 15 Plus Battery Disconnection, Remove the lower connector cover: adım 19, 3 resimden 3.
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  20. iPhone 15 Plus Battery Disconnection: adım 20, 3 resimden 1. iPhone 15 Plus Battery Disconnection: adım 20, 3 resimden 2. iPhone 15 Plus Battery Disconnection: adım 20, 3 resimden 3.
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
Sonuç
Clay Eickemeyer
97.735 İtibar
470 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
16.132 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 106
