Ana içeriğe geç
iPhone 15 Pro Max Screen Opening
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
  1. iPhone 15 Pro Max Screen Opening, Heat the bottom edge: adım 1, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  2. iPhone 15 Pro Max Screen Opening, Insert an opening pick: adım 2, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Insert an opening pick: adım 2, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Insert an opening pick: adım 2, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  3. iPhone 15 Pro Max Screen Opening, Screen information: adım 3, 1 resimden 1.
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  4. iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: adım 4, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: adım 4, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: adım 4, 3 resimden 3.
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  5. iPhone 15 Pro Max Screen Opening, Heat the right edge: adım 5, 1 resimden 1.
    • Heat the right edge of the screen until it's hot to the touch.
  6. iPhone 15 Pro Max Screen Opening, Position the opening pick: adım 6, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Position the opening pick: adım 6, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Position the opening pick: adım 6, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  7. iPhone 15 Pro Max Screen Opening, Release the right clip: adım 7, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Release the right clip: adım 7, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Release the right clip: adım 7, 3 resimden 3.
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  8. iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: adım 8, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: adım 8, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: adım 8, 3 resimden 3.
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  9. iPhone 15 Pro Max Screen Opening, Heat the top edge: adım 9, 1 resimden 1.
    • Heat the top edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: adım 10, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: adım 10, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: adım 10, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  11. iPhone 15 Pro Max Screen Opening, Heat the left edge: adım 11, 1 resimden 1.
    • Heat the left edge of the screen until it's hot to the touch.
  12. iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: adım 12, 3 resimden 1. iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: adım 12, 3 resimden 2. iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: adım 12, 3 resimden 3.
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
Sonuç
Clay Eickemeyer
97.720 İtibar
470 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
16.128 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 166
