Ana içeriğe geç
iPhone 15 Pro Taptic Engine Removal
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 15 Pro Taptic Engine Removal, Prepare your iPhone for disassembly: adım 1, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Prepare your iPhone for disassembly: adım 1, 2 resimden 2.
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Taptic Engine Removal, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Taptic Engine Removal, Mark your opening picks: adım 3, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Mark your opening picks: adım 3, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Taptic Engine Removal, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Taptic Engine Removal, Heat the bottom edge: adım 5, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Taptic Engine Removal, Insert an opening pick: adım 6, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Insert an opening pick: adım 6, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Taptic Engine Removal, Screen information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Taptic Engine Removal, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Taptic Engine Removal, Heat the right edge: adım 9, 1 resimden 1.
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Taptic Engine Removal, Position the opening pick: adım 10, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Position the opening pick: adım 10, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Position the opening pick: adım 10, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Taptic Engine Removal, Release the right clip: adım 11, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Release the right clip: adım 11, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Release the right clip: adım 11, 3 resimden 3.
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Taptic Engine Removal, Separate the right edge adhesive: adım 12, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Separate the right edge adhesive: adım 12, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Separate the right edge adhesive: adım 12, 3 resimden 3.
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Taptic Engine Removal, Heat the top edge: adım 13, 1 resimden 1.
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Taptic Engine Removal, Separate the top edge adhesive: adım 14, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Separate the top edge adhesive: adım 14, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Separate the top edge adhesive: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Taptic Engine Removal, Heat the left edge: adım 15, 1 resimden 1.
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Taptic Engine Removal, Separate the left edge adhesive: adım 16, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Separate the left edge adhesive: adım 16, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Separate the left edge adhesive: adım 16, 3 resimden 3.
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Taptic Engine Removal, Unfasten the loudspeaker: adım 17, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Unfasten the loudspeaker: adım 17, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the four screws securing the loudspeaker:
    • One 2.7 mm‑long screw
    • Three 2 mm‑long screws
  18. iPhone 15 Pro Taptic Engine Removal, Remove the loudspeaker: adım 18, 3 resimden 1. iPhone 15 Pro Taptic Engine Removal, Remove the loudspeaker: adım 18, 3 resimden 2. iPhone 15 Pro Taptic Engine Removal, Remove the loudspeaker: adım 18, 3 resimden 3.
    • A plastic buffer is adhered to the top edges of the loudspeaker and Taptic Engine.
    • Lift the bottom edge of the loudspeaker until you can grab it with your fingers.
    • Peel the loudspeaker from the plastic buffer on its top edge and remove it.
  19. iPhone 15 Pro Taptic Engine Removal, Disconnect the Taptic Engine: adım 19, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Disconnect the Taptic Engine: adım 19, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
  20. iPhone 15 Pro Taptic Engine Removal, Unfasten the Taptic Engine: adım 20, 2 resimden 1. iPhone 15 Pro Taptic Engine Removal, Unfasten the Taptic Engine: adım 20, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two 2 mm‑long screws securing the Taptic Engine.
  21. iPhone 15 Pro Taptic Engine Removal, Remove the Taptic Engine: adım 21, 1 resimden 1.
    • Remove the Taptic Engine.
Sonuç
Spencer Day
159.048 İtibar
1.043 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.922 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 120
